Giro413
- Oct 27, 2023
Hi everyone,
Left/right volume balance on Wiim ULTRA. How much is too much? Any best practices when it comes to using L/R balance settings?
My speaker setup consists of two Dali Oberon 5 floor standers and an Argon S850 sub, which is placed in the back right side corner (behind a couch) opposite of the speakers. There is roughly 3-4 meters from the Dali speakers to my listening position - in the couch (which unfortunately cannot be seen on the picture - it is behind the table). The room is rectangular, where the side with the tv is approx. 4,5m, the other 3,8m. Ceilings are 3,15m. Slanted corners in three corners (all except back right). Wooden door in the back left corner.
As you can see from the position of the tv compared to the speakers, the left speaker is further away than the right one. Of course, depending on where in the couch I am sitting, length to one or the other speaker varies. I have found that moving the balance slider in the Wiim app 0.3 (30%) to the left creates the most equal output of left and right sound when I am sitting in the couch. But it does seem to me that that is a bit much, and it also is not optimal when i am moving around the room.
I know this has been touched upon earlier, but I cannot seem to find the relevant thread. What is the best way of treating balance in my room like mine?
I realize that my speakers are at an angle when in fact the manufacturer states that they should not be. However as you can see my walls kind of dictate that. I also realize that I could easily pull out the left speaker to be at a equivalent distance from me as the right - create an equal-sided triangle and so on. However, that is what I am looking to avoid.
Thanks in advance for any considerations and advice. Will be tweaking my setup tonight listening to Nick Cave's Wild God, so shoot!
