Volume LED does not light constantly
JosipB
Amp is working without any issue.
Since I got it few months ago. volume led was lit and was working ok.
Last few days led come on when I changing volume up or down, and after few seconds goes dark.
Checked settings in app and toggle is on for volume led, if I try to turn off and on again, lets will light for few seconds and again will go off.
And suggestion what I can do about this issue?
It is not much important, but it is strange that was working until few days. ago without any problem.
Thanks.
There was a firmware update that changed how the volume behaves, there's a topic about it in the forums, change is coming :)
Ok, thanks.
But it is strange that was working ok, until two or three days ago. Latest FW is installed.
Yeah,you are right, did not noticed that FW date is 19.11.2024.
But cannot recall that I updated FW.
Any way, thanks. Waiting for new update.
The update will not revert this behaviour. This has been implemented on purpose.
But there will be a setting in the WiiM Home app, making this behaviour optional, so you can go back to the way it's been before.
