AudioPervert
Active member
- Aug 18, 2024
Hey guys.. i usually have it pretty cold in my apartment, i cranked the heatpump, now my hifi system sounds warmer too.
Just the opposite.Warmer temperature slows down speed of sound. During cold days, I can tell live PA sound system sounds crispy.
You're correct. My bad memory...Just the opposite.
Warm air make slower soundwaves, Slower sounds more crispyYou're correct. My bad memory...
Eh!Warmer air also means warmer brain, slowing down the speed of thought, greatly improving the performance of any Hi-Fi system. Slowness gives you the time to wander around the soundstage from left to right and front to far back. Obviously, 36.5° C is the perfect ambient temperature as far as sound is concerned since it is the natural temperature of our body. Room, air, music, body and brain will merge into a steady flow of musical emotion. A veil will be removed.
Yes, the veil will only be removed at 36.5°Eh!
Are you saying that the room should be warmed up to 36.5° C?
I can't stand it for 5 minutes.![]()
Who said it would be easy? Art requires sacrifice!Eh!
This is fundamentally correct; however, caution is advised when it comes to ambient music. In this case, the room should not be heated specifically to enjoy the music and should be left as it is.Warmer air also means warmer brain, slowing down the speed of thought, greatly improving the performance of any Hi-Fi system. Slowness gives you the time to wander around the soundstage from left to right and front to far back. Obviously, 36.5° C is the perfect ambient temperature as far as sound is concerned since it is the natural temperature of our body. Room, air, music, body and brain will merge into a steady flow of musical emotion. A veil will be removed.
But what‘s about ambient music in the sauna? Tricky!This is fundamentally correct; however, caution is advised when it comes to ambient music. In this case, the room should not be heated specifically to enjoy the music and should be left as it is.
Testing 29 degreeds now
I just discovered the holy grail. Set the temperature to 40c while eating icecream. Mindblow
