Weird problem
Skull
So since the last ultra update I have been getting an issue where the left channel would drop for 2-3 seconds
First thought was to reboot the ultra that worked until the next day and my first thought was oh bugger my Sonos is finally dying 😢
So tonight I rebooted both the Sonos fives and the ultra no improvement
Then while I was fixing the stand on the right side the cable was making strange noises when moved/touched
Replaced the cable tried a few tracks all seems ok but will test more tomorrow 👍
Just shows the simplest things can fix an annoying problem
And before I am asked it was a supplied 3.5to dual phono plugs that came with the ultra
It lasted a few months at least😊
I had the same problem when I bought a Wiim Mini a few years back, the supplied cable was faulty. Replaced it with another one I had and never a problem since.
Actually I think this lead was from my mini I just used it with my ultra 😊
Didn’t fix it my first track is dropping out more often now 😢
Ticket raised but I have switched the phono plugs to see if right channel drops
I've got a similar problem. When first used after period of time (a few houres), it drops audio completely for about 3 sec every 30 seconds for 10 minutes, and then its fine. I'm dealing with support over this, but so far no luck. It's like its trying to connect to something, but fails. Does this on WiFi or ethernet.
Well I swapped left and right phono plugs but left speaker still dropped 😕
After a couple of hours playing no dropouts happened so it’s very curious anyway updated my ticket hopefully they will get it sorted
And this is only since the last firmware
This does rule out the cable, but it does not rule out the device the 3.5 mm jack plugs into ...
Ok after your post got me thinking so I swapped the 2 5s removed the stereo pair and sub,was nervous about doing this as I am using 16.1 still and didn’t want to upgrade
So surprisingly it did this smoothly enough 👍
So played one track that dropped out a lot this morning and no dropouts
Will do a full test in the morning but thanks for your input hopefully this will fix it until I replace them in November 😊
Oh dear my whole system is now updating FGS
Look’s like after a year dodging this c••p they finally forced it
Couldn’t control the 5s anymore wouldn’t work unless I updated 😢
Well good news is that it still works 🙀
But omg the new Sonos App is a mess
I cannot change eq on my older iPad but can on my iPhone on ios26 beta
Never mind at least I can sell them knowing they work and not feel guilty
Ok support got back to me but I have discovered that it was a cable/sonos issue 😕
I have played 3 albums today and no issues
Wonder how Sonos manage to make you update when you make a minor change to your system
But never mind all is working again 😊
