Widget
Jay123
Hi, I would like to suggest an Android Widget to Wiim, which would have the normal controls; play, stop, pause, and the most special controls ever like: Set Input; Ethernet, Bluetooth, TV or optical in
And even more, if the widget could control both output and inputs / why not then also volume level.
This would all happen from the widget, without even opening the Wiim app. 🤞✊👍😅
Please
Upvote 2
Please
It would still have to connect to (discover) the WiiM just as the WiiM Home App do when you start it. So when should that happen?
I have not been able to get Wiim to change INPUT using either Alexa or Google Home voice control.
Is that even possible? I wouldn't want to buy that €25 remote control just to use it to change the input on Wiim. I wish Alexa or Google Home could set the Wiim input to Ethernet or TV and vice versa.
Jeesus 🙏, Could you create a widget which could also change the WiiM input that would be great 2. I've been tryna two weeks to get that input to set using eather ones voice controling capabilities, LG TV Alexa, or Google home Nest mini speaker's to just set the Wiim input. No luck.
,amen. 😅
Editing: reason, I forgot to mention something.
LG TV webos version of the wiim home app, that too will be ready later. It can also switch inputs👍 Until then, you can use that sofa baguette. 😂
See this post where Alexa routines can be setup to switch input from any echo device on your network
https://forum.wiimhome.com/threads/wiim-amp.1322/post-33581
It is shocking to me that neither WiiM or Sonos have iOS Widgets. When a phone is asleep, extremely handy to quickly pause music or fast forward. A widget should be a priority for both platforms.
If WiiM beat Sonos to the punch, and made one, it would be an advantage. A Watch app would be useful too.
