J Jules1978 Member Joined Feb 1, 2024 Messages 11 Sep 9, 2024 #1 Hi all I have a quad artera solus play and I would connect it to wiim ultra I would use the DAC of quad artera souls play and the streamer if wiim ultra Is it possible? Thanks
Skull Active member Joined Jun 20, 2024 Messages 135 Sep 9, 2024 #2 Jules1978 said: Hi all I have a quad artera solus play and I would connect it to wiim ultra I would use the DAC of quad artera souls play and the streamer if wiim ultra Is it possible? Thanks Click to expand... Yes connect using the optical/spidif connection
S slipthru Member Joined Aug 3, 2024 Messages 15 Sep 9, 2024 #3 Yes you can use coax, optical or usb output from the wiim ultra to the inputs on the quad.
harkpabst Major Contributor Joined Jan 21, 2024 Messages 2,274 Location NRW Sep 9, 2024 #4 Jules1978 said: Is it possible? Click to expand... It's even possible with room correction.
M Musician Senior Member Joined Dec 10, 2023 Messages 426 Sep 9, 2024 #5 harkpabst said: It's even possible with room correction. Click to expand... And volumeregulation in digital domain…
