obertransae
- Feb 20, 2024
since the new wiim amp pro no longer supports airplay, the feature (iphone) that you can use the phone buttons on the side to turn the volume up and down is unfortunately no longer possible.
can you make it possible to adjust the volume without having to open the wiim app / spotify app and play around with the app volume slide?
p.s. and no i never use the remote control from the wiim amp - only the phone
greets
s.
greets
s.
