WiiM Amp Ultra soft Optical input
Denus01
The optical input from my computer to the WiiM Amp Ultra is quite soft.
The pre-gain level has been set to 10 db already in the app, but even then, other inputs are way louder at 0 db.
I guess the USB will have the same issue though I didn't test that yet.
The mainboard I'm using is a Gigabyte Z890I Aorus Ultra.
Is this normal?
The WiiM don't support USB audio input, so you will not be able to test that.
With soft input I guess you mean that the audio volume is low? Did you check the PC output volume settings for the application in use and the system-wide volume. They can both change the volume of the optical output.
