For whom it may be of interest - I did compare Wiim Amp and Wiim Amp Pro the other week.
Well, how come? I did decide on a sound setup for our new second home. On the upper floor we will have a kitchen / living area, on the lower a TV and music relax space.
So I did buy us two setups based on Wiim Products:
- for the kitchen/living room a Wiim Amp with Dali Spektor II speakers (amp+speakers=480€) for background music
- for the TV and music space a Wiim Amp Pro with B&W 607S3 (amp+speakers=790€) more for listening to music and watching TV
I don´t believe in the cable-vodoo, so I am using standard copper cabling for both.
And - you might be, I definitely was curious what the differences are in regards to sound.
So I did set up the test, both setups side to side in our living room. I used room correction on both setups, using my Samsung S20 which turned out good. I also tried the flat linear EQ setup and the bass booster EQ.
I did combine the amps to a multiroom setup to ensure that both amps get the same source - and did then mute either of the amps to compare.
As a source I used hi res audio from Amazon music, music I listen to and some "specials".
In detail: I started with contemporary pop music, then old school Hip-hop, some classic stuff (orchestra and a bit of Chopin piano) then some Jazz (Diana Krall). Finally news on TV via HDMI coming from our Sony TV.
In fact I can conclude after two days of testing: both setups sound really great, I would have been happy with two times the WiimAmp and Dali setup - but the WiimAmp Pro and B&W 607S3 setup gives more clarity overall (better spoken word), also more punch in the base.
In other words: for background type of setups the WiimAmp+Dali Spektor II is a good choice and an incredible bang for the buck, for more clarity (music and spoken word) you may want to level up.
So I am extremely happy and I am sure now that I have the right setups for both purposes.
Ciao,
Stefan
