Hello all, I’ve spent a lot of time reading through the posts here and am overall loving Wiims products. I purchased a Wiim Amp after my 15 year old Onkyo A-9555 started having input selection problems.
I went with the Wiim Amp because I had previously purchased a Wiim Pro Plus to stream output from my cd transport to my other speakers which have airplay and was very impressed. It also replaced my old airport express for airplay from iphone and my smsl su-1 dac connected to my amp. My Wiim amp is connected to a pair of EPOS ELS-3 bookshelf speakers.
I’m having an interesting experience now trying to stream my vinyl records on my new system.
I have a Technics SL-1300 ->Rega Fono MiniA2D phono preamp->USB out to Airchord Stream on iphone-> to Wiim amp
vs
Technics SL-1300 ->Rega Fono MiniA2D->line out to wiim pro plus for airplay streaming to wiim amp.
When I stream the usb output from the preamp to the Wiim amp, It sounds loud, full, good, amazing with nice separation! When I use the regular line out of the rega to the pro plus to airplay stream or even straight to the wiim amp line in, it sounds flattened and lower volume. Which wasn’t the case when it was hooked up directly to my old amp.
Any suggestions to get the wiim line in stream to sound as good as the streamed usb pre amp output from the rega?
Thanks so much!
vs
Thanks so much!
