Wiim connection breaking - unstable operation
bgergo
I'm not sure if the recent sw update (5.0.716363) or something else causing issues, but I'm experiencing strange and very unstable operation of my wiim amp. Please note I have 2 devices, 1 is working correctly, the newly bought wiim amp has issues.
Problems:
- Wiim amp device disappearing from the device list every now and then
- Streaming from Spotify breaking "sounds like" nw connection issues, however the device is 0,5m from the wifi. I've tested the nw from other devices and it is stable. No packet loss, no huge ping, etc. Either the wiim amp nw device fails or the sw bug.
- I played 10 songs from spotify, but after I closed and shut down the wiim, I was not able to stream again. Not from spotify, not from tidal.
- I haven't changed anything, but now I cannot stream from Spotify nor from Tidal
- optical input with ps4 seems ok
- I restarted, unplugged, set to factory ->didn't helped.
Anyone else experiencing the same, or I should give it back to the dealer?
Thanks.
Problems:
Thanks.
Hi bgergo,
Sorry for the inconvenience caused. Please send us a feedback ticket from the WiiM Home App (select "More" tab > "Feedback"). We'll troubleshoot and resolve the issue for you immediately. Thank you for your support and patience!
Hi bgergo,
I have already created a support ticket. Is it enough? #532741
Problems:
Thanks.
Did you try an Ethernet cable from your router?
Note that you can actually get too close to the WiFi router, so that the signal get too strong. This can lead to signal saturation, reduced data dates and connection instability.
Problems:
Thanks.
My WiiM amp seems to be experiencing similar problems with Spotify Connect. Preset playback does not work and sometimes the Amp does not appear in the device list in the Spotify app. Sometimes it does appear, but is connected via GoogleCast.
I've reset the device multiple times. I was able to add the device to the list, but Not able to stream at all from Spotify or from Tidal. At the beginning the wiim amp was visible, then it was just disapeared. If the lan cable plugged in, I am not able to set to setup mode the device. I've tried multiple times, but it just does not go to setup mode (3sec play hard button). When I remove the lan cable, I can setup the device, but after the successeded setup it is just disappears. Once I plug the lan cable again, the device appears, however the mobile app shows it is offline. Everything seems quite hectic.
edit:Once I plug in the nw cable the device goes offline. The cable has no issues
Sounds like your network is somehow split into several logical networks and your phone are switching between those.
All devices must be on the same logical network. Do you have a Mesh Network or something like that?
I have a mesh, but the other node is very far from this device. The same stands for my phone. I am close to the master node with the phone. This issue was never appeared with my other Wiim Amp. Now I am connected with LAN cable for testing purpose. All devices on the same nw. I have a quite basic mesh, and none of my devices had issues in the past. From my gut feeling its either sw bug or nw device issue. I am 100% sure my nw part is stable with no interference, etc.
Ok. And your Mesh Network is working as an acces point and not as a router? Are the Mesh Network access points names unique or the same as the main router?
Support found unstable wifi at the wiim amp side. They pushed another version of the firmware, now I'm testing it. My side of the nw should not have any issues, I have 10+ connected devices on wifi and others on lan and non has any issues ever. We'll see. I get back to this post once I have finished the testing and have any results
The device has now fixed IP. It worked for an hour without any issue, then it started to have packet loss, and went offline:
Reply from 192.168.31.224: bytes=32 time=5ms TTL=64
Reply from 192.168.31.224: bytes=32 time=3ms TTL=64
Request timed out.
Reply from 192.168.31.224: bytes=32 time=6ms TTL=64
Reply from 192.168.31.224: bytes=32 time=7ms TTL=64
Reply from 192.168.31.224: bytes=32 time=105ms TTL=64
Request timed out.
Reply from 192.168.31.224: bytes=32 time=4ms TTL=64
Reply from 192.168.31.224: bytes=32 time=104ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.31.224: bytes=32 time=67ms TTL=64
Request timed out.
Ping statistics for 192.168.31.224:
Packets: Sent = 1068, Received = 1041, Lost = 27 (2% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 404ms, Average = 6ms
So after the device disconected eventually. I've used with LAN it seems ok. After I removed the lan cable the wifi worked for some minute. I disabled the 5ghz enforcement, started a new ping -t and I still have packet loss. My other wiim amp has no packet loss at all
For me the problem of unstable WiFi also started to appear very recently, probably with the 5.0.716363 software update. In addition my WiiM amp became quite slow to respond to volume changes via the HDMI interface. I was able to mitigate both problems by downgrading to 705358 via the beta program. So from that it does really feel like there is some regression in the recent update maybe?
I have 2 wiim amps. 1 is working perfectly, the recent aquired one does not. After a reset / factory reset the wifi stable for some time, but eventually it'll break and disconnects. Lots of packet loss. At this point I'm not sure if this is a sw bug or a hw issue...my guess would be the wifi module. We'll see what will the support advise
Problems:
Thanks.
The long and short of it Wiim Amp WiFi SUCKS!!! Nothing but connection issues then drop outs and reconnect failures- horrible.
the ultra works the original Wiim Mini works the amp sucks. I have several streamer amps in the same spot (Acrylic, NAD M10, Eversolo Play), they all work perfectly NOT THE WIIM AMP- it sucks.
Yours may do, but the vast majority of them do not.
If you have an issue with yours, you should submit a support ticket via More > Feedback, in the WiiM Home App.
Bold text is not needed.
Please do submit a ticket so our team can check it out, might be a problem with the unit you have, or there could be some things we can help with to make improvements. I believe the WiiM Amp has a better wireless card than the Mini, so there are likely some other factors about the placement that we can help with.
