This month's updates introduce powerful new features for the WiiM Sound and WiiM Sound Lite, along with comprehensive improvements to device management, connectivity, and audio output configuration.
Whether you're setting up your new WiiM Sound Lite, optimizing room acoustics with RoomFit™, or fine-tuning high-resolution audio outputs, these articles provide the guidance you need.
WiiM Sound Lite Updates
- How to Set Up Your WiiM Sound Lite – (New Article) – Complete setup guide for the WiiM Sound Lite. Covers initial power-up, network connection, app pairing, and essential configuration steps to get your device up and running quickly.
- How to Set Up a Stereo Pair with WiiM Sound and WiiM Sound Lite Speakers – (Updated Article) – Enhanced to include WiiM Sound Lite compatibility. Learn how to pair WiiM Sound with WiiM Sound Lite speakers for true stereo playback, including optimal placement recommendations and stereo group management.
- How to Enable Roon Ready on the WiiM Sound and WiiM Sound Lite – (Updated Article) – Expanded to cover WiiM Sound Lite. Step-by-step instructions for activating Roon Ready functionality, covering setup in both the WiiM Home App and Roon software for seamless high-quality audio streaming.
- How to Perform RoomFit™ to Calibrate Your WiiM Sound and WiiM Sound Lite for Your Room – (Updated Article) – Now includes WiiM Sound Lite support. Complete calibration guide for optimizing acoustic performance in your listening space, with device-specific tips for both WiiM Sound and WiiM Sound Lite models.
Room Calibration & Audio Input
- Perform RoomFit™ to Calibrate Your WiiM Sound for Your Room – (New Article) – Optimize your WiiM Sound's audio output for your specific listening environment. This guide covers the complete RoomFit™ calibration process, including microphone placement, measurement procedures, and how to fine-tune the results for optimal sound quality in your room.
- How to Use Audio Input Port of the WiiM Sound – (New Article) – Detailed guide to connecting external audio sources to your WiiM Sound's input port. Covers supported connection types, configuration settings, and how to switch between input sources seamlessly.
Audio Quality & Output Settings
- How Do I Get 24-bit / 192 kHz Audio from Qobuz? – (Updated Article) – Enhanced with improved formatting and additional information on Optical/COAX/USB output resolution adjustment. Explains subscription requirements, app settings, and device configuration for maximum streaming quality.
- What Is the Maximum Bit Depth and Sample Rate for Optical/Coaxial Output? – (Updated Article) – Enhanced with improved structure, formatting, and screenshots. Clarifies the technical specifications and limitations of optical and coaxial outputs across different WiiM models.
- Using USB Output on WiiM Amp, WiiM Amp Pro, WiiM Amp Ultra, and WiiM Ultra – (Updated Article) – Added visual guide showing how to adjust USB output resolution with screenshots. Covers supported formats, optimal settings for different DACs, and troubleshooting connection issues.
Device Management & Control
- How to Update Firmware on Your WiiM Device – (Updated Article) – Improved structure with new information on updating multiple devices simultaneously. Covers automatic updates, manual update procedures, and best practices for maintaining firmware across multiple WiiM devices.
- How to Manage the Power State of Your WiiM Device – (Updated Article) – Enhanced guide covering power management options, standby modes, and powering WiiM units off.
- What Does the WiiM's Built-In Microphone Do – (Updated Article) – Expanded explanation of microphone functionality, including RoomFit™ calibration, voice assistant activation, and privacy considerations.
- How to Use Ethernet Connection – (Updated Article) – Improved guide covering wired network setup, connection troubleshooting, and benefits of Ethernet over Wi-Fi for WiiM devices.
- Does WiiM Support Apple TV and Dolby Audio? – (Updated Article) – Updated compatibility information regarding Apple TV integration and Dolby audio format support across WiiM product line.
Voice Assistant & Smart Home Integration
- How to Control WiiM Device via Google Assistant – (Updated Article)) – Expanded device compatibility list and updated screenshots. Includes additional WiiM models supporting Google Assistant and enhanced voice command examples.
- Can I Use Siri to Control WiiM Mini's Output Volume – (Updated Article) – Enhanced with additional clarification and setup instructions for controlling WiiM Mini volume through Siri voice commands.
- How to Link Your Music Service to Alexa – (Updated Article) – Enhanced instructions for connecting music streaming services to Alexa for voice control of playback on WiiM devices.
- Can Alexa Be Turned Off? – (Updated Article) – Added step-by-step instructions with screenshots showing how to disable Alexa functionality on WiiM devices.
App/Software Usage
- Playing AIFF Audio Files on Your WiiM Device – (Updated Article) – Enhanced formatting with additional methods for playing AIFF audio files. Covers USB playback, network streaming, and compatibility considerations.
- Use the "Enter Pairing Mode" Option in the WiiM Home App for Bluetooth Pairing – (New Article) – Detailed guide for using the enhanced Bluetooth pairing interface in the WiiM Home App. Covers manual pairing mode activation, connection troubleshooting, and managing paired devices.
