WiiM Mini - Problem scrolling through the track
Crimson
Wiim Home version: 3.1.8.250403.611980
Firmware: 4.6.713548
Source: Synology NAS, DLNA
If Replay Gain is disabled, I can't scroll through the track. The progress bar shows 00:00 (The music is playing, but the progress bar isn't responding).
After turning on Replay Gain, I can scroll through the track - the progress bar works fine.
What I did:
1. I restored the device to its factory settings.
2. I reinstalled the app.
Unfortunately, that didn't help. The problem occurs on all Android devices (OnePlus Nord 2, 4; Xiaomi Mi Mix 2s; Samsung Galaxy Tab S8).
I'm not sure exactly when the problem started. I bought the WiiM Mini in February 2025, and everything was working then. It seems to me that it happened after a firmware update that implemented Replay Gain.
Important!
Track scrolling doesn't work in every scenario if the song is around 20 minutes or longer. It doesn't matter whether Replay Gain is enabled or disabled.
BTW
Great device. Thanks for your work :) It's just a minor glitch.
Might be an idea to raise a ticket to WiiM via the more/feedback section in the app when this occurs. That way they’ll be able to inspect your device logs and hopefully identify the root cause.
Thanks for the suggestion. I've just done it.
This error has been happening constantly since the firmware update. It's not occasional.
Hi again.
I received a different version of the WiiM Home app from customer support - "MuzoHome-20250411104808-3.1.9.250411.3741c2-final".
Scrolling through the track works fine (in any case).
We are waiting for the official update on Google Play :)
