Wiim pro buzz
Smartplug
Does anyone have issue of buzz sound coming from speaker when using Ethernet connection? The buzz disappear using wifi.
I have everything connected on same power surge with light indicator that house grounding was correct. Im not sure how to fix this so I can use Ethernet instead of WiFi.
Can you try a different router/bridge port or a different cable, or a shielded Ethernet cable (if such exist)?
