I have two sources playing to separate sets of speakers in two adjacent rooms, and inserted a Wiim pro in the signal path of one of the sources to take advantage of the room correction feature. When either the Wiim parametric or graphic EQ is turned on in the app, that introduces significant signal latency, so the sound is delayed between the two rooms. When the EQ is turned off, the sound is perfectly in sync in the two rooms, the same as it was before the Wiim pro was inserted in the signal chain. I have spent a lot of time trying to zero out the latency using the Wiim app manual sync feature, but I can never seem to zero it out. Does anyone have any idea what the actual latency is using the EQ, and how to get rid of it?
