jpinkerton
- Mar 3, 2023
I've had the WiiM Pro for about a month with it working perfectly until today. I cannot get audio from an airplay 2 source (e.g., my iphone) to play over my speakers through the WiiM. I have tried Spotify and iHeartRadio apps with no success; however, when I play a test signal from the WiiM app I can hear the audio. I tried my iphone and a separate ipad with the same result. I unplugged the WiiM and I also rebooted from the app. The WiiM is connected to my 5ghz wifi with 'very good' signal strength. I have the wi-fi roaming option turned off since I use a mesh network and the WiiM is next to one of the nodes. I also have the IPv6 option enabled. I'm using the line out signal and tried two different amps and speakers. I have app version 2.4.
I have not changed anything since I got the WiiM so I'm not sure what would cause the sudden disruption. Any suggestions or help would be appreciated.
