WiiM Pro Plus and Hi-Res Flac internet radio (riversideradio)
K-701M
Hi all,
I have a WiiM Pro Plus connected to a receiver, via analog RCA, and on some internet radio stations that broadcast in FLAC with 1400-2000 bitrate, I get some sound distortions, as if the WiiM Pro Plus processor can't handle it high bitrate. As an example, please, can someone check from this page riversideradio.nl the FLAC translation - https://stream.and-stuff.nl:8443/riverside
From the computer it sounds ok without any distortion problem.
Or maybe there is a suggestion from the manufacturer how to solve this problem? It's not the only internet radio station that causes distortions at hi-bitrate flac, I've encountered it before.
It is connected by wire, so that there are no questions about the internet channel (100 Mbps).
Thank you in advance!
I also get distortion on my Pro and Pro Plus for that link, so I’d submit a ticket to WiiM so they can inspect your device logs and hopefully identify the issue.
Hi all,
Problem solved because I have the same ????
Hi all,
Hi K-701M, Team
Our team is aware of the distortion issue with the link above. We're working on it and hopefully fix it soon. Please stay tuned! Thank you for your patience.
