Wiim Pro Plus connect to Nvidia Shield Pro
LinkUser
Hi Wiim’ers
I have my B&O active speakers connected to my Wiim Pro Plus via Coax out.
As I would like to also use my speakers for movies played on my Nvidia Shield Pro I am scratching my head on how to do that?
I have tried with an spdif out from my tv to the wiim pro plus spdif in without success.
The Nvidia Shield Pro “only” has a HDMI connection, which the Wiim Pro Plus does not.
Anyone have any suggestions?:)
Hi Wiim’ers
Hi Burnside
Thank you for your reply.
I have just double checked. My Samsung TV is set to PCM format on SPDIF-output, but still no sound….
Hi again Burnside
I got it! My mistake was that I had not enabled it on Audio Input in the app! So sorry, rookie mistake! Thank you for your help!
