WiiM Pro Plus Firmware v4.8.634146 Update - Oct 31, 2024
WiiM Team
WiiM Admin
Staff member
Moderator
Please review the WiiM Pro Plus update release notes below. If you encounter any issues, feel free to reach out to us.
4.8.634146 (In Progress)
Release date:
10 / 31 / 2024
What's New:
  1. Improved Alarm Behavior for Plex: Default alarm sound will now play if Plex server is unavailable.
  2. Playback Enhancements:
    • Fixed an issue where playback could not resume after Wi-Fi reconnection.
    • Fixed an issue preventing Audible Books from playing through Alexa.
    • Fixed noise issue when resuming Amazon Music.
    • Fixed playback crash for Deezer alarms and presets.
    • Corrected metadata for custom radio stations.
    • Fixed no sound when switching between Bluetooth, Line or Optical inputs.
  3. Improved Input Auto-Sensing: Optimized for smoother audio transitions with minimized delay.
Bug Fixes:
  1. Sync Audio Fix: Fixed an occasional error for Sync Audio.
  2. Alarm Time Fix: Corrected rare incorrect alarm issue.
  3. Group Stability: Fixed unexpected device removal from group.
  4. General Enhancements: Various performance improvements and bug fixes to enhance overall operation.
@WiiM Team
When is the Pro Plus (and Pro and Mini) going to see a Feature Roll-up of all the "general" Features and Fixes that have been released to the Amp and Ultra over the past month??
11 / 5 / 2024
What's New:
Bluetooth Sound Control: Disabled connection notifications when not in Bluetooth input mode.
Google Cast Upgrade: Fixed Output Resolution support and improved sync with Google Speaker Groups.
Playback Fixes: Improved metadata, fixed skipping issues, added WMA lossless support, and reduced Preset latency.
Bug Fixes:
Offline Responsiveness: Improved response without internet.
General Enhancements: Various performance boosts and bug fixes.
11 / 8 / 2024
Bug Fixes:
DLNA Discovery: Fixed an issue preventing device detection via DLNA.
Playback: Fixed playback issues for certain Icecast streams.
11 / 19 / 2024
What's New:
Playback Fixes: Improved metadata handling, resolved skipping/seeking issues, added WMA Lossless support, fixed Icecast playback, and reduced Preset latency.
Replay Gain: Added support for TIDAL, Qobuz and Plex (requires app version 3.0.0+). Learn more.
Bluetooth Control: Disabled connection notifications.
SoundMachine Preset: Added support for SoundMachine Preset (coming in the next app update).
LMS Enhancements: Fixed volume indicator flashing during playback.
Bug Fixes:
Offline Responsiveness: Improved performance without internet.
Amazon Music: Resolved playback not resuming after extended pauses.
General Fixes: Various performance improvements and bug fixes.
11 / 27 / 2024
What's New:
Room Correction with Independent L/R Channels: Fine-tune each audio channel independently for a richer, more immersive sound experience. (Requires app version 3.0.3 or higher)
KKBox Integration: Enjoy seamless streaming with KKBox, now fully supported within the app. (Requires app version 3.0.4 or higher)
LMS Server Selection: Select your preferred LMS (Logitech Media Server) based on IP for more flexibility in playback. (Requires app version 3.0.4 or higher)
Enhanced Alarm Functionality: If your chosen music isn't available, fallback sounds will ensure you never miss your alarm.
Playback Enhancements: Enjoy more accurate metadata, resolved skipping issues, and smoother playback for TuneIn.
Auto Timing Alignment: Automatically syncs your main speakers and subwoofer for perfectly timed, balanced audio
Bug Fixes:
Line-In Playback: Fixed stuttering issues during Line-In playback for a smoother listening experience.
General Improvements: Various performance enhancements and bug fixes for an overall better experience.
11 / 28 / 2024
Bug Fixes:
Room Correction with Independent L/R Channels: Resolved an issue that prevented Room Correction from functioning properly, ensuring a smoother user experience.
For some reason, neither delete nor edit were an option on the post I said to ignore. They show up on the ignore request, which is odd….
I think that there may be a time limit for editing or deleting posts, but if anyone wants one of their own posts deleting, all they have to do is report the post and request its deletion.
You must be right. I no longer have the option to delete my earlier post. It would actually make sense if the ability to delete posts was removed after another post had quoted them. It can get very confusing when that happens 🤣
The older product are getting behind on update with more than a month since last update. The ultra is the most up to date than any other devices on their line.
This isn't too surprising, as this is where most of the new Dev Effort is focused. And those products need to be Released in order to gather widespread feedback/field debugging.
This is the frustrating part, as we know about all the common features that could be released to Pro and Pro+ (and even Mini) with so minimal additional effort.
in the future if there’s new device that will come out that’s higher than ultra that may get the most priority. Ultra might join the rest of older product like the pro that will take long time to get update. I remember when there was just a mini and pro the pro get frequent update but not anymore. It look like the older product are just legacy.
I have to add my voice to the question:
When will we see Pro+ updates?
There are several WiiM Home App updates that have come through, yet they "require an upcoming firmware update" to be realized and that update is a long time coming.
Any news, @RyanWithWiim ?
Looks like there's an update planned this week for the Pro Plus and the Amp as well to bring some feature parity. It'll probably be the end of the week and might roll out next week depending on timing. Is there a specific feature you're interested in? I can ask about that one in particular.
