Wiim Pro Plus scrollbar does not work
Hexur
Can someone explain to me why the song scrollbar does not work for songs played from a network drive (mp3, flac etc.), but in the case of Tidal Connect it is OK.
applies to the Wiim Pro Plus
I don't have a Pro Plus, but track progress and seeking in the WHA is working for me when playing FLAC files. What server are you using, and are you performing any transcoding?
It's more than likely MiniDLNA which I have an install of and is working fine for me.
Can you post a screenshot?
what creenshot would you like?, the player window looks like it doesn't show the time, the scrollbar is at the beginning and the song is playing
I really just wanted to make sure that you weren't looking at the Devices tab as the scrollbar on that page is for volume.
Have you always had this problem? It's as if the audio is being sent as a live stream with an unknown duration.
I've never seen anything like this so it might be worth sending feedback through the WHA (Settings > Send us feedback).
EDIT: Have you tried another control point such as BubbleUPnP or mconnect?
