pjorgenunes
Valued Contributor
- Sep 2, 2024
Hi WiiM Team,
Given my speaker example their response is: low-freq cut-off frequency at 42Hz and it it decays in a -24dB slope.
The target curve should be a mix of the targe curve one chooses (example Harmon) mixed with the innerent response of the speakers as stated above. It's not good to try to correct the speakers above this "Mixed target curve".
If this would be implemented we could have good correction above 20-30Hz, not waste one or two filters, and not trying to have the speaker to respond above it's limitations in low-bass response.
Can you check on this please?
BR,
Paulo
BR,
Paulo
Upvote
1
