andreas.pd
- Nov 11, 2024
Hi all,
I am building an entry sound system at my place, which is composed of the following pieces:
- Turntable: Technics SL1200 MK-2
- Speaker: Teenage Engineering OD-11 (Cloud / Bluetooth speaker) https://teenage.engineering/guides/od-11
I am thinking of purchasing the WiiM Ultra, which can be used as a phono-preamp, but also give me multiple connectivity options. Before buying it I would like to have your consultation on the following topic:
I will connect the Turntable directly to the Line-in of the "WiiM Ultra" and from there I would like to stream sound to the active speaker via Bluetooth. Would that be possible? Do you see any issues (except the expected quality loss) with the above described co-installation?
Thanks a lot in advance for your help and your feedback.
Best,
Andreas
Best,
Andreas
