Welcome.Apologies in advance for what may be super simple questions!
- Can the WiiM Ultra transmit to Google Cast groups?
- If yes to the above, can the WiiM Ultra output simultaneously to a Google Cast group and analog out?
For sure!Welcome.
An Ultra can be part of a chromecast group, as a receiver.
Maybe describe what you were thinking of doing / how you were thinking of using it.
Oh interesting. Is there another WiiM device (perhaps the mini?) that would be able to transmit audio from a turntable to a Chromecast group or to another WiiM device? If not, how might that normally be done?The standard method is to group your Ultra with other WiiM devices. Even though the Ultra supports Chromecast, it can’t transmit to other Chromecast devices. However, if it’s part of a group with other Chromecast devices I.e. has been grouped in the Google Home app, you can send audio from your phone/tablet over Chromecast to all the devices in the group.
Ok, that makes sense.No WiiM device can transmit Chromecast, but any WiiM device can send its physical audio input to another WiiM device by grouping them e.g. if you connected your turntable to an Ultra, you could group it with another WiiM device and the audio would be output from each into whatever they were connected to, say an amp or active speaker.
WiiM are also developing a DLNA cast feature which will allow a WiiM device (except the Mini iirc) to send audio to multiple DLNA compatible speakers, but unfortunately not Chromecast devices.
In my previous testing, it works fine when the parent device has Bluetooth output.Is it possible to add a Bluetooth output to that same WiiM group? Or is that classified as another output type and, as Burnside said above, not eligible for simultaneous playback?
