Wiim ultra- Please add usb output resolution option
Please add usb output resolution option so that i can use usb exit using ddc on my old dac
USB out is bitperfect if volume setting is set to max and no EQ is used. Thus, output sampling rate and bit depth is the same as the incoming stream.
Welcome.
I don't know if / when a max or fixed sample rate option will be available for the usb output.
Wiim should be aware of this as feedback / tickets for this have certainly been raised.
Guess all we can do is wait and see. Or send more feedback!
Does decreasing/increasing (to match the amplifier) the GAIN value affect bit-perfect?
The Pre-Gain value on the Audio Input page? Yes, it does. This is digital gain so the output cannot be technically "bit-perfect" anymore, just as with EQ and RC.
On a practical level this proofs how important "bit-perfect" really is: The use of this term should better be limited to describe the technically perfect transmission of a digital signal. As soon as you actively manipulate a digital signal (for a very good reason and beneficial for you listening experience, like RC) it becomes virtually useless.
As soon as digital volume control is involved, bit-perfect loses its technical meaning anyway.
