WiiM Ultra specific conectivity questions
D
Deleted member 18574
Guest
Has anyone tried the connectivity options as per the photo below??? Would that work?
The DVD player and the turntable are inputs; the digital audio stream is going to the WiiM Ultra USB out, and then to an external DAC. Can I:
1. Control the volume on WiiM Ultra with either input selected?
2. Use the WiiM Ultra 10-band PEQ with either input selected?
Is there an embedded Spotify app, for hassle-free streaming through USB out? (I assume the 10-band PEQ will work in this case 100%)?
What is the resolution of the digital audio out (USB out) stream?.. and can it be changed for each input option? Is there an upsampled combination at which the PEQ is not available/can not be used/does NOT work?
Your help is not really help at all - completely useless. I wouldn't have spent time and effort to prepare the specific equations I have if I had been able to find the answers.
Please do not try to help further - find someone else to provide a useless answer to.
Yes
Yes
No, WiiM devices use Spotify Connect via the Spotify app. But yes, peq still works
All WiiM digital outputs are capped at 24/192, independent of peq.
Please remember that you are a new member here, and comments like these will not encourage other members to offer help or advice to you in future.
Now you know how I feel as a new member, faced with a completely useless answer as my first encounter on these forums.
You see, it goes both ways.
Luckily, a kind individual found the time and was kind enough to provide meaningful answers to my actual questions.
That individual is @Burnside - thank you, Sir.
No, I don't know how you feel, but I wouldn't react as you did after your first forum post.
With that said, Welcome to the forum.
