If I connect my Wiim Ultra to Parasound P6 via USB will I be running the signal through 2 seperate DAC's?
This is assuming I'm switching some or all inputs using the Wiim Ultra.
No. Remember what DAC stands for - digital to analog converter. If you're using a digital output from the Ultra, then the audio stream hasn't been converted to analog hence it hasn't used the Ultra's DAC
