Hello,
New to the forum. I received Ultra 2 weeks ago and today sub SVS SB-1000 . Besides them there are 2 speakers Kef LS50 and amp is Advance Paris Playstream A5 (80W) all playing in small room (11 m2) with many bare walls and some furniture.
Cable conneciton quite staighforward:
Ultra Line Out ==> AUX IN on Amp.
Ultra Sub OUT ==> LFE on SUB
In Wiim Home I set Fixed Volume Output, and use Remote of the Amp to change Volume for individiual Songs. Also Room correction seems quite useful.
Today I got my first ever Sub - SVS SB-1000. Of course I read some hints on the web how to set up sub (crossover, Phase, Level, positioning) they give useful drections. But I am miusisng the knowledge to know when the sub sounds "right".
I played a bit in Wiim Home with settings of Crossover frequency (60 - 100) and Level and Phase. For some time I got wonderful music but I continued to tinker with settings.
I found out that if I set on Amp Remote Volume to quiet, the Sub is still playing with the same volume (logical, as it is not connected to Amp but to Ultra).
So I think this solution(Fixed Volume output) is not good, the volume on Sub should change too in case if the volume of music on main speakers changes.
So I changed Audio settings - Fixed Volume to off, but now both remote of WIIM and remote of AMP can change volume. I dont want to use both, Should I set AMP volume to very high an just use Wimm, is there a right way ?
I also ran Room corection with sub. It makes very different curve. Without sub there was a big "valley" of -12 around 50 HZ.
With sub it is different, there is flat line and then around 100HZ there is seep hill to around +5
I also run with Ultra the Syncing of Sub and speakers.
An other hints how to know that volume and postion of sub are right ?
Thanks.
Lec
Any other hints how to set Sub settings, thah it is not too quiet and not too loud.
Thanks.
Lec
