Having an issue playing 176.4Kbps files. Using the WiiM Pro Plus as a streamer connected to an external DAC. I use Tidal and ROON as my source with WiiM PP Coax set at 192kbps and 24 bits. When playing 176.4K files, the output skips and distorts badly. Oddly, plays 88.2Kbps files with no problem. Also plays 192K 24 bit files perfectly. The same setup works fine at 176.4K using an old Squeezebox Touch - zero distortion. Is the Pro Plus able to play 176.4K files? Thanx.
