I purchased the wiim pro plus a few days ago it was initially connected to my amp a Rotel ra5 and works no problems, out of curiosity I connected it via coaxial cable a Vandamme 75ohm into a cambridge dacmagic 100.
All seemed to work OK until I tried a 24/192 file from Qobuz then it intermittently drops the sound it plays clearly without distortion but then stops and starts again. I have tried changing the settings to a lower setting 24/96 and it plays fine. The wiim test tone also drops in the same fashion on the higher resolution.
I am a thinking it could be the cable at fault but don't have another digital cable to try. Can anyone recommend a cable they use that works? I am in the UK was looking at the chord cline as I use their rca cables to conect to amp.
Thanks in advance for any help
