Amp has odd behavior after running room correction
Woody
Active member
Location
Midwest US
This has happened at least twice to me after running room correction. The amp won't play either as a part of Amazon Music group or just through the Home app. I then reboot the Amp and eventually it will start to play, but out of nowhere the room correction audio sweep plays. It does it two to three times all on its own. Nothing on the app shows the RC running.
Vague information because it happens unexpectedly and I just poke around on the app until it starts working again, but basically the RC runs ok, but then Amp won't play. Reboot and RC sound sweep a couple of times, more reboots and then finally back working properly. iOS and I believe the latest firmware and app.
Anyone else run into this?
Nope. Did you send feedback to WiiM through the WiiM Home App? If not, it's best to do so right after the issue occurred. Your device logs will be included for WiiM to check them.
