Amp Ultra / Vibelink combo - min impedance and possible zoning
Cplus
Looking to understand whether a system per below will work as I’m hoping.
Have a Large rectangular open plan living/dining area, and an outdoor area adjacent.
Would like to pair 2 left and 2 right of the IC50 and then the tropix in stereo for my outdoor area.
Questions
  • Impedance.. would like to run the IC50 in pairs connected to a wiim ultra amp. So would present a nominal 3ohm load if wired in parallel - will the amp ultra cope with this?
  • Zoning. looking to connect a vibelink off the amp ultra to run the outdoor speakers as mentioned. will the setup allow playing music outdoors but not indoors? Or will I be limited to running the indoors only *or* indoor and outdoor - but never outdoor only?
  • Apple Music. As a family we use Apple Music, the kids both have apple home pod minis and we also have a HomePod in the kitchen. will I be better to change to a Spotify subscription with the wiim or is there easy ways to play Apple Music despite the lack of airplay?
Thanks in advance for any insight or links to previous threads.
You couldn't drive the indoor speakers and the vibelink/outdoor speakers at the same time - WiiM devices only allow one output at a time. That may be academic though as the Amp Ultra only has USB audio out but the vibelink doesn't have USB audio in. You may be better off considering a second WiiM Amp for the second zone, which you could group with the first.
Re Apple Music, much has been discussed in the forum - briefly, you'd need to add a device like a Belkin Sound Connect cabled to the WiiM Amp Ultra (or even a WiiM Mini) to act as an airplay gateway. Going back to your first scenario, rather than a vibelink, a vanilla WiiM Amp could provide Airplay and drive another zone as well.
See https://faq.wiimhome.com/en/support/solutions/folders/72000563311 for more FAQs around Apple Music, bearing in mind the absence of airplay for the Amp Ultra
Edit: I'll leave it to others to comment re driving multiple speakers
thanks for the reply.
One output. Right. That is interesting indeed. And a major miss on my part thinking it had more than just USB out!
I think a “vanilla” Wiim amp x 2 (or 3) is definitely going to be a consideration.
No, you should not try to run pairs of the IC50 in parallel with any WiiM amplifier (and basically with most ampliers available on the market). It's the minimum impedance leading to trouble, the nominal impedance is mostly useless. The minimum load would be 1.8.ohm and few Hi-Fi amps can handle that.
You could wire them in series instead of in parallel. But in this case the maximum volume would be somewhat limited (and the wiring may be no so intuitive). It could still work, depending on how loud you want them to play. Their sensitivity is pretty much average.
