Are there sound quality benefits in upsampling to 24/192 using the ultra when outputing optically to a DAC?
PavlosN
I see that when outputting digital signal from the Ultra to a separate DAC one can set a fixed resolution such as 24/192, which I assume means that the signal is upsampled by the Ultra if it was originally at a lower resolution.
Is there a sound quality benefit to doing this or should one always output the signal at the original resolution?
One reason to use higher sample rates is to avoid the pre-ringing that comes from a steep brick wall filter. A 22 KHz brick wall filter creates pre-ringing in the 18 KHz range. Some people say they can hear that pre-ringing, but those people are few and far between. The pre-ringing in a 192 KHz sample rate is far outside the normal human hearing range. That has to be weighted against the quality of the upsampling routine.
So, technically - maybe. Practically - probably not for the vast majority of people..
24bit makes it easier to use it as a pre-amp without worrying you'll lose information when lowering the volume.
I might be ignorant here, is DAC always outputting 24bit? I thought it outputs 24bit only when resampling to 192Khz.
No, the sound gets slightly worse using the fixed upsampling resolution. The same story happens with most streamers. Using the original sampling frequency always sounds better to my ears .
