Audio Pro C10 MKII Wiim edition availability from France
frbona
I am currently trying to purchase Audio Pro C10 MKII Wiim edition on amazon.com but it is not eligible for shipping to France.
Could you please help me to find a dealer ?
Thanks,
François-Régis
What is the difference between the wiim edition and the normal version which is available in Europe ?
The WiiM edition has the WiiM firmware as in other WiiM devices. The European version only includes the LinkPlay software that WiiM is built upon. So limited functionality.
Ok thanks.
When you mentioned limited functionalities, can you give me some features which are missing in the european version ?
Ok thanks.
Enhanced EQ, PEQ, room correction, squeezelite client etc- and currently, the newly released Qobuz Connect
Ok thanks.
You can try to install the Audio Pro app and see what is available. It works with the WiiM devices but only for the features also available on standard (European) version.
Ok, i had a doubt regarding this point and now you confirmed what i thought.
Anyway, i will get the standard version. It fit my needs regarding music streaming (24bits/192khz, Tidal Connect,...)
You may need to check in advance if Tidal can play 24/192. At least my A10 WiiM Edition can only play up to 24/48 on Amazon Music.
Honestly, my first choice was to buy a second wiim ultra and plug it to active speakers. But i do not have enough space in my bedroom in which there is already a streamer and 2 speakers.
That is the reason why i decided to get the C10 Mkii which is pretty much easier to install near my existing speakers
