Would it be possible to make the Audio (Volume Balance), Fade In/Out and Subwoofer setting entities available for Home Assistant? I often use the balance change because the room I'm listening in isn't the best, and such a change would allow connection to some automation. It could also be one of the presets selectable from the remote, although it doesn't seem necessary. It would be great to be able to access the PEQ settings from the HA.
Upvote
