Audio Settings memory by song
Jtiano53
So many songs are produced with center balance off making for an unbalanced sound stage. Using the audio settings adj. compensates for center balance. Problem is some are left of center and some right of center so you have to adj. for each song. Setting memory by song would be great and reduce ongoing adj.
Upvote 0
Is that really a problem if that is how they wanted it? Also could end up be a lot of data to store and search through
There is artistic placement of voices and instruments for desired effect. But even these recordings have a center sound stage to optimize artist or engineer choices.
Traditionally , a listener would adj balance on their sound system to center up the recording. WIIM Ultra control means less interruption in sound stage balance process. I suspect those who have great sound stage reproduction systems notice when the recorded stage is not centered. This is of course influenced by room acoustics and speaker placement.
Adding by album or song adjustment memory is an engineering challenge with multiple possibilities. WIIM could create something new and unique. Perhaps, one of your clever engineers could find a method to analyze the song and find what should be a left right balance for the recording. Then there would be no need to fine tune on a one by one basis and no need for memory.
I must say this sounds like a very niche requirement and one which I feel could divert development resources away from more important features, notwithstanding the negation of the artistic placement you mention.
