I have a Yamaha amp with Canon S70 Speakers attached.
WiiM Pro Plus
I also have a Sonos system. I cannot sync the audio automatically or manually.
From the WiiM app I use Airplay to connect to the Sonos.
However, if I try and sync automatically I actually lose all the sound once the auto sync finishes syncing and when I check the app the settings for the output have changed.
You would think changing it back would work but it takes a few minutes to changing various settings on audio in and out before it starts working again albeit out of synch
I also noticed that when I first start to use WiiM with my amp and i change the audio output to Airplay, it changees my amp from CD to Airplay but of course, then I could not hear anything
TIA
Steve
WiiM Pro Plus
TIA
Steve
