Can we pleas get auto resume on tracks over 20 minutes from USB, also what would be nice is also a pop-up on the app asking me whether I want to auto resume a track shorter than that, furthermore if at all possible would be a setting in the player where you could change the behaviour at will to fit how you use the device, so being able to change the length of a track before auto resume kicks in and if you want auto resume on at all and whether you want the pop up.
Reason why is music tracks are extremely rarely over 20 minutes, and if they are that long really scrubbing to the beginning isn't a big deal and you might actually want to start the track where you left off in the track, I listen to audio books from USB on my WiiM Amp, so that I don't have to run down my phone battery especially at night because I have ADHD and listen to an audiobook I have listened to before helps me sleep, but also at the same time I will decide to go to sleep and then do 5 more things before I sleep so I will pause or switch what I am doing meaning the audiobook will get started and stopped several times and it's annoying having to find where I was each time.
if I could move files onto the USB device from my phone that would be the icing on the cake, preferably if the app just created a folder location with all the sub folders on the USB device copied to the folder location on the phone where if I drop a audio file inside the folder and sub folder location on the phone I can transfer files to the USB device in the correct folder location, so that I can use File Manger+ to move files from my NAS/PC to the USB device in the WiiM amp directly that would be a cherry on top, also if I create a new sub folder on the phone in the folder location it will create that same folder location on the USB device.
Bonus sprinkles if I have to confirm I want to transfer over the files and it will automatically delete the files in the folder location on the phone after transferring them, throw up a warning and a double confirmation that the files will be permanently deleted from the phone and that if you want the files still on the phone copy them to another folder outside the WiiM folder.
Upvote
