TreadsOrTrails
- Dec 27, 2024
I have some Kef LSXii wireless speakers and a KC62 Sub. When I play wirelessly through my iPhone there is a lot of some kind of interference that sounds awful. I found that if I have a wired source to the Lsx ii's the issue is gone. I bought the WiiM ultra to establish a wired connection. So far it solved the interference issue. I connected the WiiM to the Kef's using an optical cable. It sounds a little flat compared to using a USB connected from my MacBook Pro to the LSX ii's via USB. I need some advice on how to connect everything.
1. Should I use an optical cable or the RCA outputs from the WiiM to the Kef's? Why?
2. Should I connect the KC62 Sub to the Lsx ii's or to the Sub output on the WiiM?
3. What settings should I play with to get the best sound?
Thanks!
Thanks!
