I'm having an issue with 2x WiiM mini's when output is selected to Bluetooth.
When I stream audio (any input) into each WiiM mini, Bluetooth output (connected to my Bose Minilink), as a single device works fine, no issues.
When I stream to 1 WiiM mini (any input) and try to "multi room" to the second WiiM mini, Bluetooth output fails / is intermittent. Ive also got a WiiM Pro Plus, & when I try to stream music to the Pro Plus (any input) & then expand to the WiiM mini's, Bluetooth outputs on the WiiM mini's doesn't work randomly starts / stops. Aux out works fine?
Ive done some basic checks in the app, no success. Both my WiiM mini's act the same & both WiiM mini's are located next to my Bluetooth speakers? Can anyone help?
