Cannot pair remote with WiiM Pro
Robjbrad
I reset both, tried new batteries but it will not pair. It tries and I get the dialogue saying it will take up to 30 seconds.
Have you tried a full factory reset of the Pro?
Thanks for replying, yes and I’ve tried pairing from different devices (iPhone / iPad). It can see the remote and gets to the pairing screen but never completes. I’ve got a month before I have to return it, I suspect this is a firmware issue.
Hi, go through trying to set up the remote again and when it fails, go into settings/feedback in the WiiM Home app and submit a ticket - WiiM may be able to diagnose your device logs and identify what’s at fault. They will be able to determine whether your device (remote or streamer) needs replacing if it doesn’t appear to be an easily solvable firmware issue.
Same issue here. Remote just went dead. Changed batts, etc. Can't re-pair. Even reset the device and still not remote connection. Doesn't even light up when I press the any button.
Please contact your dealer or submit a ticket through the feedback section of the WiiM app.
