Chromecast volume regulation is not exponential, and it is awful
anli
I use Pro as a Chromecast device with Ethernet input and coax output.Volume regulation on the device page of WiiM Android app is far from be exponential (in other words, from be linear id decibel scale). It is both very unusual and unhandy.
Is it my experience only? What do you think?
So this means you don't have fixed volume enabled. Are you seeing the same thing when you regulate volume from the Google Home app?
Sure. I want to regulate a volume from the WiiM app (or Google Home) rather to take long trip to amplifier.
Yes, the behavior absolutely in par with Google Home control.
Just imagine, say, the aim is to get 50 db range for regulating. Then, 50% of the regulator control is -25 db. But it seem to be linear instead, that is 50% is just -6db.
