Coax vs Ethernet
tarnopol
So I've found that odd behavior that the second I plug in Ethernet, my Coax Out stops working. Can someone confirm that their WiiM Pro is working with Ethernet and Coax Out? Does mine have a mechanical problem?
Coax and WiFi = no problem.
Ethernet and Spdif = no problem.
Thanks!
Also on the latest firmware version? Mine is 4.8.513047.
Yeah, and on all the previous versions since December.
Try a reboot and if that fails, submit a ticket thru the feedback section in the WiiM app so they can review your device log.
Same here. Might be the cable. I found an old combo rca/coax cable from when we had dish network. Connected the coax part from the wiim to my soundbar and it just works. Wiim box is connected via ethernet to a network switch. The cable gives me the additional option of a line out/in.
I also set in the app interface for coax and tested to insure highest bit output.
