Control speaker volume when outputting to airplay speakers
basti
Hi, it would be helpful to be able to control the individual airplay speaker volume from the WIIM app when outputting to multiple Airplay speakers via the WIIM Pro.
This is already possible.
First pair your AirPlay speakers as you usually do, then select AirPlay Out
Then select the Speaker symbol
Then adjust individual speaker volumes using the sliders
Thanks for the reply! I don’t have sliders though :(
Firmware version is latest.
App version is latest too
