- Mar 2, 2024
Thanks for the suggestion, I will definitely take a look at it.You could probably try ocenaudio if still looking for the software.
Just note the trial version of Vinyl Studio does not remove clicks and pops from LP's. Only the Pro version and above will do this. It is well worth it, as removing clicks and pops on older/worn LP's is really annoying in the digital world. You will find this out in the trial version.I shall have a look at the Behringer devices that you have mentioned.
It will probably be worth having a play around with VinylStudio and my Rega Fono, to see what the results sound like.
I have already started ultrasonic cleaning my records, and the results are surprisingly good.
I thought the trial version did remove clicks and pops. It wouldn't be much of a trial version if it didn't.Just note the trial version of Vinyl Studio does not remove clicks and pops from LP's. Only the Pro version and above will do this. It is well worth it, as removing clicks and pops on older/worn LP's is really annoying in the digital world. You will find this out in the trial version.
I am pretty sure the trial download is only the Standard version, which does not have the ability to remove clicks/pops. When I tried to use the option (it does appear in the dropdown) a message popped up stating I needed to purchase the Pro version. Needles to say, I was not happy.I thought the trial version did remove clicks and pops. It wouldn't be much of a trial version if it didn't.
The standard version does have declicking etc but the Pro version has more filters IIRC.I am pretty sure the trial download is only the Standard version, which does not have the ability to remove clicks/pops. When I tried to use the option (it does appear in the dropdown) a message popped up stating I needed to purchase the Pro version. Needles to say, I was not happy.![]()
You are correct. The purchased Standard version of Vinyl Studio does have most all features including de-clicking. But in my trial version, de-clicking is not available.The standard version does have declicking etc but the Pro version has more filters IIRC.
I have never needed Pro.
Edit
See Feature Highlights
Record LPs and Tapes to CD and MP3 on your PC or Macintosh
VinylStudio software makes it easy to transfer your records and tapes to CD and MP3. Runs on both PC and Macintosh Computers and includes a full set of sound cleaning filters.www.alpinesoft.co.uk
Isn't it just manual click repair that isn't available. My trial version says "You can use it in the trial version (or in Vinyl studio Lite) but if you subsequently upgrade to VinylStudio Standard you will no longer be able to"You are correct. The purchased Standard version of Vinyl Studio does have most all features including de-clicking. But in my trial version, de-clicking is not available.
I have resolved this issue, it wasn't to do with the TV settings, it was a Windows Display setting for Scale, I had it on 300%, so I have reduced it to 250%, and now the whole GUI is visible, albeit slightly smaller.On my setup, the GUI seemed to be too high to fit my screen properly, with parts of it off the bottom of the screen, and I didn't seem to be able to resize the image, but could drag it up occasionally to see what was at the bottom.
I should add that the screen I am using is not a PC monitor, it is 40" 4K UHD TV, so I may be able to play around with the TV settings to remedy this issue.![]()
Thanks for the offer to convert the files, but I have now downloaded the dbPowerAmp Music Converter trial version, and have converted the files, and imported them into iTunes where they have now synced with my Mac, and iPhone. I must have selected the wrong file format because they have ended up as AAC audio files at 256 kbps (VBR).Converting files. The swiss army knife is dbPoweramp reference edition that includes a great conversion tool - dbPowerAmp Music Converter. As a one off if you post them to dropbox or similar I can convert for you.
Slider greyed out. Normal in some circumstances with USB inputs.
1 Clipping is not bad. You should see the VUs go up into the yellow. If you apply and use ReplayGain tags afterward you'll get good volume levels.
You probably need to remove the ones on the Mac and re sync.Thanks for the offer to convert the files, but I have now downloaded the dbPowerAmp Music Converter trial version, and have converted the files, and imported them into iTunes where they have now synced with my Mac, and iPhone. I must have selected the wrong file format because they have ended up as AAC audio files at 256 kbps (VBR).
I reconverted them, and on my Windows PC, they show as Apple Lossless audio file, with the first track being 16 bit 44.1000 kHz 739 kbps, but when I checked the synced version on my Mac, it shows as AAC audio file, with that same first track being 16 bit 44.100 kHz 256 kbps (VBR).
I checked this the other way around by comparing the details of a CD that I added to my Mac, and the situation was reversed, the first track was Apple Lossless audio file, 16 bit 44.1000 kHz 662 kbps, and the synced version on my Windows PC was an AAC audio file, with that same first track being 16 bit 44.100 kHz 256 kbps (VBR).
This seems very odd, and I will have to do some research into this before proceeding to digitise more albums.
I removed them on both devices, and then re added them on the PC.You probably need to remove the ones on the Mac and re sync.
