I have two issues with the Wiim mini that are happening so frequently it is unusable.
1) While casting from the Amazon App, the music just stops playing. The Amazon music app is no longer connected to the mini and can't reconnect. This has happened 3 times this morning in less than an hour
2) While casting from the Amazon App, the app disconnects from the mini and can't reconnect. In this situation the music continues to stream on the mini
In both situations the only way I can connect the Amazon app is to clear the app cache and force a stop.
I am using using Amazon Music App on Android either from a Galaxy A54 or an Amazon Fire HD tablet. All apps are on the latest version. I have a mesh network configuration with 3 nodes. The mesh and internet connectivity is solid with no issues - the mini shows wi-fi strength as very good when checking immediately after the issues have happened.
The only support advice has been to switch off preferred DNS. This has made no difference. Wiim are no longer responding to my support requests.
Does anyone know how to fix this? I have got to the stage where I am going to return the mini to Amazon as faulty and get a replacement to see if that fixes the issues.
