That’s it settled thenAmir at ASR concluded that Wiim PEQ did not degrade sound quality (ie significantly affect SINAD)
See what you did there. Yes of course ASR are not the final word on anything but the balance of measurement with logic and listening, rather than just a golden ears approach feels about right.That’s it settled then![]()
Can you remind me what tests he performed with PEQ?Amir at ASR concluded that Wiim PEQ did not degrade sound quality (ie significantly affect SINAD)
on the ultra not tested..on pro plus just engaged the peq without any correction...Can you remind me what tests he performed with PEQ?
Fixed.![]()
WiiM Pro - Review & Measurements (Streamer)
WiiM Pro - Review & Measurements Hey folks, It is time for my first review of 2023... This one is about a complete objective analysis of the new WiiM Pro streamer. The aforementioned has been recently announced, back in November 2022, and I can see quite a strong hype around it since. That...www.audiosciencereview.com
Here the reviewer says,
"Obviously, you do not want to use EQ at fixed volume, unless 57dB SINAD (before D/A conversion) is something you are looking for... It becomes way cleaner with volume is unlocked, the lowered at about 95%. This issue could be easily fixed by firmware, by setting max volume about 1dBFS down."
Since then some changes have happened in the app. You no longer need to unlock the fixed volume to lower it. You can do that in the volume limit and keep the fixed volume on.
So I am wondering if I still need to do that or is the issue fixed. Or I only need to lower the volume when I apply positive gain in the EQ.
The best thing with the WiiM PRO, pro + and ultra is the PEQ function . If you use it ( you should ) one cant hear any worsening off the sound. It sounds as clean as before, and the soundstage is intact . Its the same when using the digital output to a dac.I am using PEQ in Wiim Pro to compensate for room modes. Does this degrade the sound quality in any way? Also I have only applied negative eq and did not increase the value in any frequency.
To me, this all sounds better using PEQ settings to deal with (bass) room nodes. You can easily compare by turning on/off PEQ while listening. If you have bass issues in your room and you take them away, by judiciously using PEQ (only cutting, no boosting), everything will sound better ime.Resolution, clarity, soundstage, refined, etc.
Was it fixed through an update? So now I only need to lower the volume if I apply positive gains in the EQ?Fixed.
Yes, fixed through an update. It's a bit more complex but simplified version looks like you said, needed only if a positive gain is applied.Was it fixed through an update? So now I only need to lower the volume if I apply positive gains in the EQ?
The purpose of EQ is to change the sound, in the first place ...If it degrades or improves sound quality is a matter of what you prefer. Simple as that. It definitely changes the sound quality.
I think it’s a silly question if it changes something for better or worse as that is highly subjective. Some people loved Beats headphones when they first came out… It’s like asking if food tastes better with salt. Have the confidence to taste on your own and make up your mind.The purpose of EQ is to change the sound, in the first place ...
I think the question was really asking if there were any negative consequences of using EQ like increased distortion etc.I think it’s a silly question if it changes something for better or worse as that is highly subjective. Some people loved Beats headphones when they first came out… It’s like asking if food tastes better with salt. Have the confidence to taste on your own and make up your mind.
Each 5% of the limiter has 3 dB attenuation.It would be good to have a headroom slider with -3db steps
I have seen no evidence of this advanced algorithm to avoid clipping and it has never been mentioned in the forum before. I wonder who wrote it.A happy Wiim Pro owner here. Having the Wiim volume set to fixed I have been somewhat reluctant to use the EQ though.
In this and other threads on this forum regarding EQ, the consensus seems to be that that clipping can/will occur in a situation like mine: having fixed volume (or at 100 %) and using positive gain in the EQ.
Wiim though, states the following:
https://faq.wiimhome.com/en/support...ow-to-use-parametric-eq-a-comprehensive-guide
Is it unnecessary to decrease the volume or having digital headroom when applying positive EQ gain, since with the mentioned “advanced algorithm” there will be no clipping or increase of distortion, or am I missing something?
