there is conversion in all cases...If I activate the graphic equaliser on an analogue input stream, does this trigger an analogue to digital conversion?
Thanks
So there is no way to send an analogue signal straight through to the amp?there is conversion in all cases...
Sorry canard, dont know what "is numerised in input" meansthe signal ana is numerised in input..clearer? A/D...
The analog input is always digitised.So there is no way to send an analogue signal straight through to the amp?
Hi,I see now I have gotten confused. All signals coming INTO the wiim are digital, so if the graphic equaliser is used will the signal be coverted to analogue and back to digital if the optical output is selected?
Simple!Hi,
I am no expert but it seems unlikely that Wiim would turn a digital signal (which it would be for the equaliser to work) into analogue, then back into digital to send a digital signal down an optical pipe. I imagine that for cost purposes alone the number of such conversions would be minimised.
Perhaps someone with more detailed info will put us right!
You certainly seem confused now.How can ALL signals coming into the WiiM be digital. Your post was about an analog input. The analogy input is passed through an A/D converter to allow digital volume and EQ.I see now I have gotten confused. All signals coming INTO the wiim are digital, so if the graphic equaliser is used will the signal be coverted to analogue and back to digital if the optical output is selected?
As described in comment #9You certainly seem confused now.How can ALL signals coming into the WiiM be digital. Your post was about an analog input. The analogy input is passed through an A/D converter to allow digital volume and EQ.
Indeed. Also why does autocorrect keep randomly changing analog to analogy?As described in comment #9
It probably does so to remind you that the proper British spelling is analogue ...Indeed. Also why does autocorrect keep randomly changing analog to analogy?![]()
Maybe you should just abbreviate it to “anal.” (and occasionally intentionally forget the period...Indeed. Also why does autocorrect keep randomly changing analog to analogy?![]()
I am never sure which to use, like program or programme. In that case I reckon you have Computer programs but Television programmesIt probably does so to remind you that the proper British spelling is analogue ...![]()
Yeah, I try to reserve “program” for software and programme for everything else. And “disc” not “disk”I am never sure which to use, like program or programme. In that case I reckon you have Computer programs but Television programmes![]()
Don't take away my personal little pleasure of posting in American German English on ASR and British German English here.I also tend to think that American English spelling is the way it is because the Mayflower Pilgrims threw what they saw as unnecessary letters overboard to keep the cargo weight down![]()
