I have 12 WiiM Pro Plus. Whenever there is a firmware update, and I open the WiiM Android app, I'm prompted to install the update. There is no indication of which device is being upgraded.
Then, once it's finished, I have to not just close, but forcibly kill the app, and then re-open it. And I get prompted again, to upgrade the next device.
And so on, 12 times.
It takes on average 5 minutes to upgrade a single device, and thus, for me, it takes 1 hour to perform a firmware upgrade. And that's if I watch it and kill the app every 5 minutes. I have not been doing that, and started the first device upgrade about 10 hours ago, and I'm still not done with all of them.
Improvements I would like to see :
1) if there is more than one device, show the list of devices that can be upgraded upfront
2) have a checkbox for each entry on the list to enable/disable the upgrade. All devices should be pre-selected by default
3) once the upgrade is approved, have all the upgrades performed in parallel, with a progress bar for each
These devices are all independent of each other, so there is no reason they can't all perform upgrades at once
