wiimamp user
- Jan 12, 2024
Do you have the amp?I do not see the update?
Ok don't know if you will get the update on a later time?Yes, I have the Wiim Amp
Firmware updates are rolled out in stages over a few days, and you may be one of the first to receive it. My own WiiM Amp has not yet received the update, perhaps tomorrow.Ok don't know if you will get the update on a later time?
Bluetooth worked wellFirmware updates are rolled out in stages over a few days, and you may be one of the first to receive it. My own WiiM Amp has not yet received the update, perhaps tomorrow.![]()
Is it possible that your WiiM has already completed the update? Just in case, check the current firmware version in the speaker info.I saw the update yesterday. Tried to download it and it wouldn't do it. Then it immediately disappeared again. It's almost like they pulled it for some reason.
No, it's definitely still on 5.0.609856. It didn't even download the new one.Is it possible that your WiiM has already completed the update? Just in case, check the current firmware version in the speaker info.
Hope you will receive it soon.Still no update yet for my WiiM Amp.
