WiiM Ultra Firmware v5.2.739061 Update - Dec 18, 2025
5.2.739061 (In Progress)
Release date:
Dec 18, 2025
Bug Fixes:
  1. Multiroom: Fixed an issue preventing multiroom setup with some routers.
  2. Google Cast: Fixed missing subwoofer bass output and EQ not working.
Using LMS, I do get the exact screen that you posted, but I have not yet tied my Ultras to Lyrion, I was hoping to find a decent stream using the Wiim app
I searched for "Lyrion Music Server" in Google Playstore on my Android phone, it lists it but does not show any actual LMS app. Plenty of other options but none of them are LMS? If I can find one, I will then tie the Ultras to LMS as there is a far wider choice of IR stations in LMS. The one I did download - but have since uninstalled - was the first option I found in the Playstore - Music Maker, MP3 Player - but that has nothing to do with LMS.
Sorry, my mistake and poor memory re the Lyrion “app” . You actually need to download and install the apk file from this link https://f-droid.org/packages/com.craigd.lmsmaterial.app/ and it relies on you already having the material skin plugin installed on your LMS server.
Another Android alternative is Squeezer.
If you install either of those, the Ultra will simply appear as another player - I don’t know what you by tying the Ultra to LMS.
